21 - 26 of 26 Posts
· Registered
Discussion Starter · #21 ·
OK, the Enfig kit will work for shallow depth units. However, it does not include the HVAC control relocation bracket. You could go with a BMW one (preferably), but they are pricey. Or the kit I bought at WMT (drop shipped from Metra), was only $69 plus taxes. Other places, it is @$100. The rest of the items appear fine but see below.
For the harness, you will have to transplant a lead to allow connection to the SWC lead on the E46 connector. I just bought two harnesses (the harness only part is this) and was able to move a pin from one to the one I used. With the SWR-A, only the volume up/down and track/channel up/down buttons are functional. One issue I have noticed with the SWR-A during limited testing is that the track down button just starts the same track from the beginning. The radio channels work fine up and down. Once I start driving the car again, I will be able to look more into this.
Separately, I am still waiting on a trunk handle gasket from ECS, so my car has been sitting. Thankfully expected to show up tomorrow, and I will be able to button things up and start enjoying the unit.
· Registered
Discussion Starter · #22 ·
Update: Car is buttoned up and everything works well. In summary (my opinion only), the radio installation is easy compared to installing the camera. I did not tap into the trunk lamps at all. All connections were completed at the receiver end (video, power and ground), at the parking brake, and reverse trigger at the black box above fuse panel. Adjusted the camera angle such that I can see the bumper edge, and then took the car to a local Costco and calibrated the parking guidance lines in the parking lot. Due to the offset camera mounting and wide-angle camera view, the parking lines appear triangular. However, I am able to center in the parking spot easily using the lines. Looks a bit funny on the display though. Here is a shot of the camera mount. I have a new BMW rear emblem on hand; will install after detailing the car soon.
Additional Update: After playing with the steering wheel controls, I have full track and radio channel, up and down functionality. So, the SWR-A SWC interface works fine.
Automotive tail & brake light Car Vehicle Vehicle registration plate Motor vehicle
· Registered
I just stumbled upon your thread, as I am installing a new Pioneer 7600NEX in my Wife's 330Ci 'Vert, and want to add a backup camera. I have been looking at the illuminated license plate light mounted cameras, but am concerned about picture quality, especially at night. What model camera did you install, and how do you like it?
Thanks!
· Registered
Discussion Starter · #25 ·
Look at post number 19 and you will see some installation related pictures. I used a Pioneer camera and like it immensely. Post # 22 is the finished product on the car. I want to replace my back-up lamp assembly as the lens cover has yellowed out a good bit. I may also update my back-up lamps to Philips or Sylvania LEDs for better lighting. The back-up picture quality is excellent; could be better at night, but I believe it is related to intensity of lighting at night.
· Registered
Thanks!
I decided I wanted a centrally mounted camera, so I wne with a license plate mount, and will run the wire through therubber seal of the trunk release. I am also using an RCA extension from the head unit to allow me to easily change the camera without tearing apart the dash again. It's a CCD camera sovwe'll see how it turns out!
21 - 26 of 26 Posts
