I am installing an almost new Pioneer AVS-2330NEX DD DVD unit in my 328Ci with the Hifi system, not HK. It is a DVD unit and hence not shallow. Thus far, I have procured the following items:
- The AVS-2330NEX referenced above. Unit is pretty nice with Apple CarPlay, Android Auto, HD radio etc.
- A new Pioneer NDBC8 back-up camera. Need to figure out how I will mount this camera. Will at least run the wire from the head unit to the trunk initially. Will also tap the appropriate leads from the radio harness to the parking brake and reverse wires in the shifter (if possible), hand brake area of the console.
- This Metra (95-9313B) installation kit.
- This Scosche (ICBW1BN) wiring harness and antenna adapter. I will also buy a spare one (BW01B) as I believe the plug is missing the SWC wire. Will transplant a wire into the connector I use.
- This steering wheel interface (Crux SWR-A). The Crux site indicates this is compatible with the 328Ci. I could have got this Crux (SWRBM-57K) but saved a good bit on the SWR-A. Hopefully it works.
- A Crutchfield advisor indicated that I would need a line output converter and recommended this unit (Crux CS-LOC1). Do I really need a LOC for my non-HK 328Ci?
