1 - 8 of 8 Posts
loving the new head unit. only complaint so far is that i may need a glare guard, it is a bit tough to see the display when the top is down.
906437
Can you add some photos from other angles, please?
I printed out the 9" model's screen template and played with positioning, but couldn't find a balance between the upper vents and hiding the HVAC controls that I thought I could live with.
Thanks!
Discussion Starter #6
Thanks!
here you go... i think there were 5 notches for height of the install. it was initially installed (first photo of posting) on the 3rd notch from bottom, but that was blocking the vents a bit too much.
these photos - display was lowered to 2nd notch from the bottom. now vents are only blocked slightly and there is plenty of room for hand on shifter.
906724
906726
906727
906728
906729
906730
906731
906732
906733
And that explains a few things. You went with a double DIN kit and HVAC control relocation even though the floating Pioneer's only have a single DIN chassis. I was doing mock-ups with a single DIN install and leaving the HVAC controls and sunglasses holder in place.
I also hadn't considered shifter clearance, but that's a definite concern now that you've mentioned it...3 pedal here.
Unfortunately, the more I look at head unit replacements, the more I'm leaning toward the BlueBus option with my CD53. Especially with a 'vert and all of the audio\visual environment compromises that entails, it's just hard to justify the expense and effort of even a basic aftermarket head.
Thanks again for sharing the photos, they were very helpful.
Discussion Starter #8
i started with oem navigation and hk setup. the had the Dynavin N7, which was okay, but lacked BT functions beyond phone calls. and yes, the pioneer unit is a bit pricey.
1 - 8 of 8 Posts
