1 - 8 of 8 Posts
I'm looking for a close up picture of a 02-03 sedan with DDE or DAE.
All the pics a have seen where either coupes or 99-01 sedan.
Any issue in installing it ?
Hey bro,
I dont have any sedan pics, but there is no problem with installs on any e46.
John V
Discussion Starter · #3 ·
when I look at my light enclosure I don't see how the halo will fit. That is why I am requesting a closeup pic of one light.
:dunno: :dunno:
They don' fit too well on facelift models because of the larger outer headlamp diffuser,the inner headlamp is the same as pre-facelifts so fits ok.
Discussion Starter · #6 ·
Does the halo touch the inside headlight trim ?:dunno:
No,cause it would sit higher up like the inner halo,it's just that i took the picture without altering the headlamp surround to allow the outer halo to sit like the inner halo. I didn't wan't to Dremel the housing to allow the outer halo to sit in the same position as the inner.
Here's a pic of the headlamp assy,you can see the complete refleector with it circumfrence in line with the trim,so it wouldnt foul the inner trim,plus there is a gap between the reflector and the trim so even if the halo was the same size it still would not touch the trim
1 - 8 of 8 Posts
