P0171 is not necessarily a vacuum leak, though likely that is part of it. It is only one bank, which would suggest a sensor issue on that bank, but I suspect that both banks have high LTFTs and only one is high enough to trigger.
You should do a proper smoke test or pay someone to do it. You should also replace every vacuum hose, o-ring, and seal that touches the intake. It is not expensive:
DISA gasket GA-BM-DISA-ORING-M54-S 1 $5.65
Intake manifold gasket - Elring 11611436631 1 $22.52
Air temp sensor o-ring 13621743299 1 $0.27
Dipstick upper o-ring - Reinz 11431717666 2 $0.24
Dipstick lower o-ring - CRP 11431740045 1 $0.38
Engine air distribution o-ring - Elring 11617502761 6 $5.94
Throttle body gasket 13547504728 1 $4.44
Intake lower boot 13541438759 1 $10.03
Intake upper boot 13541705209 1 $14.46
Silicon vacuum hose - black - CRP 11727545323 2 $5.42
Use the hose to replace the line from the SAP to the SAP solenoid, from the solenoid to the one-way valve, and the one-way valve to the manifold.
Replace the line from the F-connector to the fuel pressure regulator.
If you have a vacuum canister, replace the line or cap the port for it.
Make sure the large port cap on the back of the manifold is intact (it probably isn't)
If your valve cover gasket is more than 80k, replace it. Easy.
That will put you in good stead on leaks (yes, brake booster can also leak, it is not hard to test if you are interested)
Then if your fuel pump is over 125k, replace it.
If your pre-cat sensors are over 100k, replace them.
If your MAF is over 150k (frankly over 125k), replace it.
Somebody will accuse me of "throwing parts at a problem", but it is just maintenance. I have never heard anyone say that changing oil at intervals is "throwing fluids at a problem". You can't test a MAF (unplugging is not a diagnosis, it is a parlor trick, and cleaning is not useful). You can diagnose O2 sensors (not simple, you compare them against response rates of a known good emissions system), but your car is likely well over 100k, and they are wear parts.
If you are manic about diagnostics (which I respect) then get OBDFusion and ignore the codes. Focus on fuel trims.
- If your fuel trims are high at idle and low at cruise, it is likely a vacuum leak (leak becomes a smaller percentage of overall air volume as speed increases)
- High at speed and low at cruise is more likely fuel pump (increasing demand stresses a failing pump more)
- High at both is likely sensors.
But honestly, it is probably all three. It is not clogged cats or a bad ECU. It could be bad gas (it isn't).
If you pulled the manifold, replaced everything underneath ($66-200 depending on if you do hard lines and OFHG), then replaced the O2 sensors, fuel pump and MAF (about $462), your car would run fantastic.
You can't get a dealer to replace two FCABs for that money, so it is a steal, and you will pass emissions for the next 8 years.
As one of the old guys on this forum would say: In the end, it was the MAF...
