I have replaced 3 of the PDC sensors in my e46 with these one's from Hella (2 of the old one's didn't work outright, one showed irregular and wrong readings). There was only 1 good old one I kept, and I checked that it worked fine in all 4 positions so the wiring isn't a problem.
With the broken sensors I used to get a long beep when putting the car into reverse, even with 3 of the new sensors in and the 4th old one unplugged I still got the beep, but when I finally connected all 4 sensors and put the bumper back on, I now get no long beep, but also no sound at all, regardless of how far I am in front of the object behind me.
I checked with INPA and every single sensor was showing up and reading correct distances with a few cm of variance to the object behind, moving back and forward they changed accordingly, didn't get any error codes.
But again, I get no tone to indicate how far the object is behind me, while in ISTA I found a reading that says "PDC System not active" or something along those lines, what could be the cause of this and how would I go about "activating" the PDC system?..
