1 - 8 of 8 Posts
I have done search to no avail.
The passenger door is stiffer than the driver side when closing and opening. The handle works fine. Its just the door thats stiff, you have push it harder to close.
Discussion Starter · #6 ·
There has to be fix for it. Its PITA having to slam the door.
I have tried WD40. No go.
Put grease on the hinges and the rod that extends from the body into the door.
Otherwise, have more females ride as passengers in your car. :idea:
How does the bodywork look on the right side? Straight/parallel lines? Do parts of the interior (carpet, panels, trim) look like they've never been taken/moved/replaced?
1 - 8 of 8 Posts
