1 - 7 of 7 Posts
I ran into a problem... I washed my grilles with alcohol before starting. i applied a good and even coat of Rustoleum Automobile Primer, which says quick drying in 15-20 mins. Its been about 40 so far and its still wet. Can it be beacause its slightly cold outside? (60 degress?) i wiped that coat off with a paper towel and tried sanding a little and applied another coat. i figure ill give it the night to dry and check in the morning. any suggestions?
Discussion Starter · #2 ·
:bump: plz hlp... i dont wanna have to drive tomorrow with no grilles...
St. Louis BMW Fanatic
Are you painting directly onto the chrome?
You should also try to use some adhesion promotor. I use Bulldog Adhesion Promotor when I clear coat CF parts and it helps a lot.
The temperature also makes a difference.
Discussion Starter · #5 ·
yea i tried going directly over the chrome paint, i though primer was capable of doing that and the DIY directions i got said to do that... i dont know, ill see what its like the the AM and if its wet ill either go get a diff primer, or go to BMW and fork over 85 for a new grille :thumbdown:
SBBMotorwerks
60 degrees isnt that cold....the paint shouldnt still be wet after 40 minutes.
Try this.....get a pretty rough sandpaper, and sand the grille.....i did this before i primed the chrome....it gave the primer more of a surface to adhere to. I did a couple coats of primer, with a bit of light sanding in between coats to smooth things out. Once the surface was the way i wanted it (smooth and uniform), I started with the painting.
You shouldnt have to fork over another $85 for new grilles. If nothing else, use a hair dryer to help it dry. Or do what i do....paint outside, and then bring it inside to dry between coats.
SBBMotorwerks
Also....make sure you give the grille plenty of time to dry once you are done....i didnt wait long enough and when i went to put the grilles back on, i left my handprint in the paint....so i had to basically start over.
1 - 7 of 7 Posts
