After reading multiple posts I didn't find a post identifying a simple procedure when trouble shooting P0491 P0492, or a post highlighting my specific problem.
The procedure below may not be an accurate representation of the flow of vacuum but it helps easily isolate hoses and parts. Ironically, the last item on the list was the fault, a vacuum hose with no noticeable tears or leaks.
If an item is good/working it gets the OK
If an item is questionable it gets ?
If an item was easily replaceable with a free or inexpensive salvage part it gets SALVAGE.
Don't purchase any parts until ALL vacuum hoses are verified or replaced.
1. Hose, intake to check valve: OK
2. Check valve: SALVAGE $0
3. Hose, check valve to solenoid: OK
4. Solenoid: SALVAGE $0
5. Hose, solenoid to SAP valve: OK
6. SAP valve: SALVAGE $0
7. Hose, SAP valve to SAP
8. SAP: SALVAGE $26
9. SAP fuse 50 Amp: OK
10. SAP fuse 30 Amp: OK
11. SAP relay: ?
12. Hose, intake to reservoir: Oily
13. Reservoir: OK
14. Hose, reservoir to firewall: New
8. SAP: SALVAGE $26
11. SAP relay: ?
13. Reservoir: OK
