Hope someone can help. So I keep getting a p0444 code, and after investigation with a scanner, I find that my short term fuel trim value on bank 1 is around +17% and Bank 2 is around 3%. I have noticed the error is apparent after filling up, as the values go back to normal a day after filling up. Now I have removed the hose work to check if the valve is producing vacuum, but nothing at all. I have checked for air leaks but all good. I have access to a multimeter, is there any voltage check I can do on the valve itself? Also any other ideas?
