I've spent the last 2 hours searching, and most results were both a p0171 and p0174. I only have the p0174 code. with both codes, everyone was saying things that would apply to both banks. so what would allow the car to run perfect, yet throw the p0174 only code? i read somewhere that the intake gasket was split into bank 1 and bank 2. so if that's true, then there could be a leak on the bank 2 gasket. no one seems to think the O2 sensor could be bad. i swapped the plugs on the pre-cat sensors and the p0174 code went away, engine ran rough, and i had pending codes:
P1343 Misfire Cylinder 1 With Fuel Cut-off (BMW)
P1345 Misfire Cylinder 2 With Fuel Cut-off (BMW)
P1347 Misfire Cylinder 3 With Fuel Cut-off (BMW)
so that would be bank 1 reading off bank 2's sensor. what i was hoping to see was the p0174 go away and then p0171 come up, which would point to a bad sensor. i plugged the sensors back in correctly and the car ran smooth again.
i've checked the vacuum lines i could without tearing the engine apart. i had the lower intake boot off a couple months ago and it was fine. with the split behavior the car is showing (bank 2 lean or misfires bank 1) and that there's no common link in the faults, it makes me want to steer away from the common vacuum leaks that would affect both banks.
i need some input. what else could cause this split performance?
