I am running out of ideas on what to do next on resolving the P0171 and P0174 lean codes on my 2002 330Ci. (I would like to thank all who have had this issue before me for posting in forums everywhere...I have read them all it seems)
Here is the laundry list of things I have done:
Home made smoke test did turn up leaks
Intake leaks plugged
DISA O ring
Upper and lower intake boots
Intake gasket
Injectors professionally cleaned and flow tested with new O rings
O rings on the distribution pipe
CCV/Oil seperator and it's plumbing
Fuel filter
Vacuum line to fuel filter
Vacuum line from vacuum pump check valve to valve at back of manifold
Clean IAC
MAF Swap (Crappy one off ebay but still should work(waiting for the flame:evil
Air filter
Dip stick o-rings
IAT sensor
Fuel tank breather valve (had a different code for this)
Fuel pressure tested 50ish PSI
Intake vacuum tested 18ish mmHg
Oil filter housing seal (car had a bad oil leak for some time when I was told would cause the vacuum hoses to be in the condition they were in... mushy and falling apart)
Here are the items due to be replace:
Valve cover gasket (on hand)
Throttle body gasket (on order)
Air pump hose (not leaking but crusty)
Plumbing before the air box (on order)(was missing when I bought the car, could air from the engine compartment which is HOT and turbulent cause a MAF misreading )
Next steps (I guess):
Fuel pump
OEM MAF
DISA
DISA O ring
Intake gasket
Fuel filter
Clean IAC
Air filter
Dip stick o-rings
IAT sensor
Fuel pump
OEM MAF
DISA
