1 - 10 of 10 Posts
Like most members on this forum the "chrome" trim on my 2004 330ci was badly oxidized when I bought the car two years ago. I quickly found out that the trim was not chrome but was in fact anodized aluminum. Over the years I have tried several polishes but nothing worked. About a year ago I found a kit offered by Bavarian Autosport made specifically for this issue but the $60 price tag made me hesitate. After a few more failed attempts with other products I broke down and bought the kit. Here are my results.
The kit includes a bottle of cleaner, a roll of masking tape, 2000 grit sandpaper, a bottle of aluminum deoxidizer, an applicator, a bottle of aluminum deoxidizer remover and an instructional disc.
<a href="http://s75.photobucket.com/albums/i298/jconchj/Trim/?action=view&current=IMG_2749.jpg" target="_blank"><img src="http://i75.photobucket.com/albums/i298/jconchj/Trim/IMG_2749.jpg" border="0" alt="Photobucket"></a>
Here is what the trim looked like before.
<a href="http://s75.photobucket.com/albums/i298/jconchj/Trim/?action=view&current=IMG_2750.jpg" target="_blank"><img src="http://i75.photobucket.com/albums/i298/jconchj/Trim/IMG_2750.jpg" border="0" alt="Photobucket"></a>
<a href="http://s75.photobucket.com/albums/i298/jconchj/Trim/?action=view&current=IMG_2751.jpg" target="_blank"><img src="http://i75.photobucket.com/albums/i298/jconchj/Trim/IMG_2751.jpg" border="0" alt="Photobucket"></a>
I am not going to make this a how to because the supplied video does a good job of walking you through the process.
However, I will tell you to go ahead and tape all edges. I have some buffing to do on one side because I was a little sloppy with the sanding.
<a href="http://s75.photobucket.com/albums/i298/jconchj/Trim/?action=view&current=IMG_2753.jpg" target="_blank"><img src="http://i75.photobucket.com/albums/i298/jconchj/Trim/IMG_2753.jpg" border="0" alt="Photobucket"></a>
Here is the finished product.
<a href="http://s75.photobucket.com/albums/i298/jconchj/Trim/?action=view&current=IMG_2754.jpg" target="_blank"><img src="http://i75.photobucket.com/albums/i298/jconchj/Trim/IMG_2754.jpg" border="0" alt="Photobucket"></a>
<a href="http://s75.photobucket.com/albums/i298/jconchj/Trim/?action=view&current=IMG_2757.jpg" target="_blank"><img src="http://i75.photobucket.com/albums/i298/jconchj/Trim/IMG_2757.jpg" border="0" alt="Photobucket"></a>
<a href="http://s75.photobucket.com/albums/i298/jconchj/Trim/?action=view&current=IMG_2758.jpg" target="_blank"><img src="http://i75.photobucket.com/albums/i298/jconchj/Trim/IMG_2758.jpg" border="0" alt="Photobucket"></a>
<a href="http://s75.photobucket.com/albums/i298/jconchj/Trim/?action=view&current=IMG_2756.jpg" target="_blank"><img src="http://i75.photobucket.com/albums/i298/jconchj/Trim/IMG_2756.jpg" border="0" alt="Photobucket"></a>
I am very pleased with the results. It is not perfect but it is a huge improvement. Overall, I would give the kit a B+. I will update the thread once I see how well it holds up. If anyone is interested in the kit it is part number 07500100002 at Bavarian Autosport.
Nice job. FYI, Klasse AIO is an excellent de-oxidizer as well on chrome & aluminium. You can try that as a final step on top of this product.
Discussion Starter #6
Nice results. Makes be wonder, though, if simply wet-sanding w/ 2000 grit would do the trick.
After I finished wet sanding it didn't look bright and shiny. It was like polishing your paint but not applying sealant or wax. The "aluminum deoxidizer" is a water based sealant that dries on the trim like a clear coat. This appears to be what you are paying for. I have tried the $4 Noxon product as well as several other polishes but they just temporarily make it look better because they do not protect the trim.
Below is a link to the "how to" videos.
http://www.classictrimcoat.com/testimonials.html
Discussion Starter #7
The final step up this kit is a sealant so the Klasse would most likely remove it. It may be a good first step to eliminate some of the sanding.
Discussion Starter #8
Noxon metal polish will do the same thing for about 4 bucks
Noxon was one of the last things I tried before buying this kit. It would make the trim look better for a short period of time but then the oxidation would come back. This kit seals the trim so hopefully it will keep the oxidation from coming back.
So far WD40 is the best temporary solution I've found.
I was thinking about brushing my trim instead of restoring or painting it. Probably just wetsand it with 1500 slowly
1 - 10 of 10 Posts
