I recently changed my Denso plugs for the proper NGK's, and after only 500-or-so miles on the Denso's, the plug on cyl 5 had some oil on it; when I changed to the Denos from the first lot of NGK's there was a bit of oil on plugs 4, 5 and 6. I've changed up to 5W-40 oil (from 5W-30) to see if this helps, but if it does not, I've been advised to try a "piston soak" at my next oil change because oil control rings are known to stick on the M54. I wanted to see if anybody had done it before.
It was explained to me as follows:
remove plugs and pour 10 ml of some sort of injector cleaner (I've already got some Liqui Moly 1803, so that's the one I would use) into each plug hole,
leave as long as possible, but at least overnight,
disconnect DME and fuel pump and turn the engine over a few times with the plugs out to get the cleaner out of the bores,
change the oil immediately
I have done the CCV test (no vacuum when the oil cap is removed, and air comes out of the filler when I blow into the brake booster hose), and plugs 1-3 were all clean so I must assume the CCV is working correctly.
Is this piston soak safe? If so, has anybody got any data on the results?
Thanks,
M.
Thanks,
M.
