1 - 5 of 5 Posts
Oil Service Interval Reset..."4.02" ??????
Ok,
My production date was 11/2000 so I was able to use the Odometer Reset trick to reset my Oil Interval.
My question is what does this mean?
After it reset, it went to Inspection 15250. Then it says "4.02" in the display and "SIA" in the upper right corner. Then it says "End" in the upper left and "SIA" in the upper right.
What does the "4.02" mean???????
taken from www.my330i.com
RESETTING OIL SERVICE INDICATOR:
If your OBC needs to be reset after completing your oil change, there are two ways. NOTE: If you miss a step, just turn the key back off and try again:
A. Model Year 1999 to Mid-2000: You should have the older round 20-pin DLC connector under your hood behind the battery terminal, you need to use a small length of wire to connect (short) pins 7 and 19 for 3-5 seconds with the ignition key in position 1 (Accessory).
B. After Mid-2000: You should not have the 20-pin DLC connector. You only need to hold the left odometer reset button while turning the key to position 1 (Accessory). Keep holding the button for 5 or so seconds until any of the following shows in the display: OIL SERVICE or INSPECTION with RESET or RE. Release the button and press it again for another 5 or so seconds until RESET or RE flash. While the display flashes, press the button one more time briefly. If done correctly, END SIA should show up for a few seconds. All done.
Same exact thing happened to me. Did you every find a fix?
Slpnbyu said:
Ok,
1 - 5 of 5 Posts
