1 - 3 of 3 Posts
I have a flickering oil warning light on the dash and was told that it could be a faulty sensor. What's the best way to replace it and where is it located?
What color is the flickering light? If it is yellow it could be the sensor is going bad. It's an easy fix the next time you change your oil. If it's red that says that your oil pressure may be low or the oil pump may be failing.
1 - 3 of 3 Posts
