Also, when tightening it, you need to keep the alignment as close as you can get to original.
On the top, stick a screwdriver in to stabilize it so it doesn't turn into the engine...should be parallel with side of engine. I've heard and believe that the crimps really don't take to torquing.
BTW, if you're leaking from the crimps, the hose is gone, but if from the banjo bolts at the end, a tightening and/or new crush washers might do the trick. Also, so you know, it's a strong hose, so don't worry about it popping apart or anything...it'll keep until you replace it.
Oh, finally, make sure you're just not noticing PS fluid dripping on it...the larger PS hose on the reservoir has a mesh covering which seems to carry PS fluid back a bit and then it drips off. Inspection mirror and flashlight will show whether you have these hoses seeping...trim off a little bit of hose...new hose clamps and you should be good. If PS fluid isn't pink, though, change it...either turkey baster or just drain from the pump...where you'll want another hose clamp on too probably.
GL...hth
