I replaced the gasket last week, but it's still leaking oil.
I'm tearing it down again, and had a couple questions.
1. Is there a particular re-assembly pattern for the housing bolts? Like on a head, or intake manifold.
2. What are the torque specs for the housing bolts?
Not to be a buzz-kill, or anything, but are you sure the housing mount gasket is the leak?
The VANOS Oil Supply Line MUST be removed to get the housing off, and if you twisted the hose against the fittings, then you destroyed the fittings and this is the new source of the leaks. If you removed the bolts holding the housing on, and simply pushed the housing out of the way so you could get to the gasket, then you twisted the fittings on the hose, and this is a bad thing.
You need to remove the two banjo bolts, one at each end, and take the hose off. The hose has fittings that are crimped on, and if the crimp is loose then oil can come out. This is a high pressure oil supply, so the integrity of the fittings is very important. You are gonna need the 4 copper washers to seal the banjo bolts again.
Since you are gonna need the hose and washers, you may as well get a new gasket.
Having said that, I think you can remove the hose without taking the housing off. If so, and the crimped fittings are damaged, then you can replace the hose and washers without disturbing the housing, saving the need to go after the gasket again.
