I have been a member on here for a while and performed numerous DIYs including the dreaded starter replacement. (which turned out to be good. :facepalm
I followed the OFHG replacement DIY with no issues, except that it leaks worse now than before.
I seated the gasket properly and used 24 Nm torque in a cross pattern on the bolts. I also replaced the Vanos oil line and the crush washers. I have taken the housing off a couple of times now to make sure I did everything correctly. The third time is supposed to be a charm right?! I'm trying to stay calm because I love the car, but I'm about ready to rage and sell it if I can't fix it.
I noticed in the OFHG DIY several people have the same issue, but I haven't seen anyone post what the final outcome was.
Anyone have any ideas? Thanks for the help in advance.
