61138377072 will fit for the switch. Pins are 61138369696
check under the shift boot (remove the shifter trim), there is 2pcs 3 wire connection there thats unused now and you might cut it instead. not sure if this will fit but i was looking at it yesterday they look identical.wow, thanks, i was going to make an ecs order but i might try my local dealer first.
This was awesome. I like to think of this as the "Mad Max" way to do a tranny swap.The way I did it, three times now, is to slide the tranny under the car, position yourself right under where the tranny goes, pull it up onto your chest, using your knees steady it and just push it up into position. It only weighs about 80 lbs, plus you can feel it slip on to the pilot bearing and the splines. It only takes about a minute to get it in place, put a couple bolts in finger tight and proceed as normal.
could use some help regarding my pedal assembly. it has two older style clutch and cruise control switches i believe. it doesnt have a mounting spot on the slave for the 4 pin clutch module. not really sure what i need to do here...do i just simply not use the two switches and get a new slave and clutch switch module? any help is appreciated. i made a thread but thought maybe someone here would know what im talking about.
http://forum.e46fanatics.com/showthread.php?t=1117355
i'll take a look at that. mine is 10/1999, when i go to realOEM it shows the 4 pin clutch switch module and says "to March '01", i was hoping i could just follow titaniumcranium's instructions and be goodHi, i jsut did this on my car. Take a look here:
http://forum.e46fanatics.com/showthread.php?t=1112050&page=2
If this doesn't answer your questions, let me know. Seems you have the two 3-wire switches, so you are doing better than i was.... I have the clutch switches correct now, but i still haven't re-coded the car yet. BTW - what month and year was your car built? Mine is 04/2000.
just did this on my 328i engine (used to be 2000 323i wagon).. same pedal set as yours. remove and throw that white 4pin connector as you'll be using the one in your car.i'll take a look at that. mine is 10/1999, when i go to realOEM it shows the 4 pin clutch switch module and says "to March '01", i was hoping i could just follow titaniumcranium's instructions and be good
cool thats what i need i guess...so much info in these massive threads it can be hard to sort through it all. for what its worth are you able to simply upgrade to the 4 pin clutch switch? that seems to be a little bit easier. and what exactly does that coding portion do? is that coding the DME to think its a manual?just did this on my 328i engine (used to be 2000 323i wagon).. same pedal set as yours. remove and throw that white 4pin connector as you'll be using the one in your car.
wiring below post #332, coding is post #322 by Terra.
http://forum.e46fanatics.com/showthread.php?p=15622438#post15622438
Look at my post #387 above, it addresses an error in RealOEMcool thats what i need i guess...so much info in these massive threads it can be hard to sort through it all. for what its worth are you able to simply upgrade to the 4 pin clutch switch? that seems to be a little bit easier. and what exactly does that coding portion do? is that coding the DME to think its a manual?
you can use the two three-wire switches, no reason to buy more parts, just wire up the switches you have
