Awesome -- thanks for the reply Zach. That's just the kind of info I was looking for. Which flywheel did you end up using?I did a 6 speed swap on my 325. We needed a new flywheel. In addition to a 330 driveshaft, you'll also need a differential flange from a 330 -- the 325 uses a 4-bolt flange and the 330 uses a 6-bolt.
We pulled a flywheel from a manual transmission 330 -- the engine blocks on both models are the same size, so it bolts right in.Awesome -- thanks for the reply Zach. That's just the kind of info I was looking for. Which flywheel did you end up using?
Ahh OK. The 330 flywheel came with the transmission I bought so I should be set there.We pulled a flywheel from a manual transmission 330 -- the engine blocks on both models are the same size, so it bolts right in.
Another option is to use the 325 SMG driveshaft if you don't want to swap flanges. Rare to find used thoughI did a 6 speed swap on my 325. We needed a new flywheel. In addition to a 330 driveshaft, you'll also need a differential flange from a 330 -- the 325 uses a 4-bolt flange and the 330 uses a 6-bolt.
That's an interesting option that I never would have thought of. A cursory look though confirms that they are indeed rare! I came up empty.Another option is to use the 325 SMG driveshaft if you don't want to swap flanges. Rare to find used though
Pretty sure the only Getrags were the 5 speed used in the 323/325 and the 6 speed used in the M3/M5/540.So I finally got the transmission I got off ebay...and to my surprise, it's a Getrag, not a ZF. The seller insisted it came out of a 330i ZHP. Does anyone know whether the ZHP ever came with a Getrag transmission?
Thanks blarf. In the meantime, I found this thread:Pretty sure the only Getrags were the 5 speed used in the 323/325 and the 6 speed used in the M3/M5/540.
im guessing the same goes to the auto trans harness like below? just tucked them zip tie somewhere safe?Yup - just tucked all those cables and connectors out of the way under the console
