TitaniumCranium, you are the best - thanks so much for doing this! I put the dash back together yesterday, but put a length of wire/loom behind the dash from the cluster to that fuse block. After reading more of your earlier posts, I did figure out by color/wire description what specific little module I was looking for, and I left that loose from the main block until was sure and can get back in there to attach it. I pulled the connectors for both the pin 7 and the blue/yellow x428 connection from the donor car, so I have the right parts in place to make this work!
I understand I need to get the coding done before this will actually tilt the mirror, and the cable I have (which works on my 2011 X5) doesn't seem to want to connect to the E46. I also have an Autoenginuity scan tool, and between that and the simple Peake reader, I can see the ECUs and get simple fault codes, but the cable I bought to do the coding won't connect. (yeah, it's from ebay...but it looks exactly like the one linked to in the bmwcoding.com forum
). So I may not be able to test it until I get the right cable...
Thanks again for ALL of the amazing information throughout the years that this thread has been active! It made the difference between not attempting the job and getting it done!
