OEM or Aftermarket DISA Valve?
42718 Views 57 Replies 30 Participants Last post by  lilbimmer
I searched here and also google but I can't seem to find anything about it?
I've been running on a bad DISA valve lately and I'm looking to buy a new one.
I saw a couple of repair kits but I think buying a new one would give me a peace of mind lol.
Has anyone here bought the DISA valve for VAICO brand? I was thinking of getting OEM but it's almost $300 compared to $180.
Which one do you have?
1 - 20 of 58 Posts
He just stated he doesn't want a repair kit. If OP is in the same situation as i was, his valve is internally damaged and needs a full new unit. From the looks of it, OP just missed the low price. Since late last year, bmw increased their prices for this item by about $80. I purchased mine last year in May and it cost $180.
OP try to find who the actual manufacturer is, it may be Vaico.
DISAs are overrated. They have a minimal impact on performance during daily driving. I started to replace mine with the Dorman product, and found out that Dorman only makes DISAs for the 330 manifold. Then I mixed up some plastic epoxy, coated the control arm shaft with it (this is where it wears), put it back together, aligned it, let it set up, and installed it. It was a $7 fix and I'm happy with it so far.
But, if you are going to replace it, I recommend OEM. Yeah, it's $120 more than VAICO, and $293 more than plastic epoxy, but what's your peace of mind worth?
that's if your flap is busted. My problem was internal... it made a noise even though the flap had minimal play and pin looked solid.
op what's your issue? is it the flap?
Sent from my SGH-I727R using Bimmer App
The best option is a Bavarian Auto Recycling DISA valve... You get a guaranteed OEM part at a non-OEM price. http://www.bmrparts.com/
Check them out, I used them for all my parts, especially since my bimmer is nearly 14 years old with over 342,000 miles. It's just not worth purchasing new OEM parts unless I can't source through Bavarian. Just my two and a half cents worth!
That's the thing. It does make a noise and the flap is loose. I don't want to buy a $80 repair kit just to fix the flap. The car has well over 120k so maybe time for a new one.
Do some research on aftermarket one first and then decide. You're on the right track thinking this way. I decided to go with a new one no matter what at 90K with the old price. At $300 OE, I would consider Vaco but just do some reearch first.
I put up the wrong link. DUH!
http://www.germanautosolutions.com/...sa_gold_valve/product_m54_disa_gold_valve.php
It's expensive, but you won't have to worry about it failing again.
If you buy an OEM or aftermarket DISA the bellcrank assembly will fail again and you will need another one. The GAS kit eliminates the failure points. Many, many, many people I know have done it and have been VERY happy for $80. Seems a waste to buy an OEM one to me. Kind of like buying an OE VANOS kit when you have Beisan available.
considering a new unit should last 100k, and his old unit is 120k, id get a new unit altogether. it is a mechanical valve and does fail internally as well.
He says his failure is internal which a GAS kit won't address. So it appears he needs the whole shebang.
$414 dollars my dude...is that a joke?
Like I said, it's expensive. What they do is buy an OEM DISA, and upgrade it with their kit. Hence the high price. His kit is stellar and you will have a DISA that will probably never fail on you.
Alternatively, you could get the one linked to above, still get the GAS kit for $80, have the same thing as the GAS Gold DISA Kit, and come out $80 ahead.
this is not an item that fails often. 100K+... its a one time replacement for 90% of the owners.
I know.. That's a little too much for me.
Anyone here bought an aftermarket one?
Just giving him options. It's no skin off of my back whatever he ends up doing.
first, 330pilot was just trying to show him the best product. sure its expensive but its also upgraded with the gas kit.
Its definitely a one time replacement. Hopefully. Likely.
Second, Most people on this forum would recommend "you stick with OEM unless you want to be back here in 6 months with yet another DISA problem." Or something like that, I personally think you would probably be fine going with an aftermarket brand like Dorman, however I won't recommend that.
Heres a review of the Dorman here:
http://forum.e46fanatics.com/showthread.php?t=965136
1 - 20 of 58 Posts
