1 - 4 of 4 Posts
Hi,
I have some question about the oem monitor part number 65.52-6 934 410 is that built in radio module? Can I connect that oem nav. Monitor to oem cd changer?
And where can I get the connector convert the original connector from business CD to oem nav. Monitor two 12 pins connector?
Thank you!
Premium Member
Hi,
Thank you!
For cars with Nav, the radio is in the trunk. You need to do a complete Nav retrofit in order to get that monitor to work.
Here are the instructions. $4k in parts new, $1600 used.
http://www.bigpatsfans.com/nav/UltimateRetrofitPart1.pdf
http://www.bigpatsfans.com/nav/UltimateRetrofitPart2.pdf
Discussion Starter · #3 ·
1 - 4 of 4 Posts
