Hey- in adendum to my other stereo post, as I mentioned, I'm looking to build an MDF / fiberglass enclosure to fit into either corner (preferably left, but right is ok too) for a single 10 or 12 boston pro sub...
Ideally I'd like a sealed enclosure, though I've heard of alot of guys building boxes in which the driver fires down-and-in, and the box actually has a slot-port facing into the trunk sideways (towards passenger side).
has anyone used, seen or best, BUILT anything like the above? If so would you be kind enough to supply (or sell me) blueprints? I've got alot of experience with fiberglass and with custom installs- I used to make door pods out of pour-foam and fiberglass... I'm trying to maintain as factory a look as possible- so don't be misled, the fiberglass is NOT for a trick looking install- I want low-key, matching carpet- very unobtrusive looking, just something to fit as best as possible without forgoing alot of trunk room- also soemthing that will sound nice and tight, which is why the sealed box is my favorite idea- I don't mind if the sub is visible (which I think it would have to be if it was a sealed box- it would have to fire into the trunk, unless someone has a mind-blowing install idea)
Anyhow- PLEASE- post away- LET 'ER RIP - I want your ideas and thoughts on this... Also, please share your ideas with the factory head unit + amp idea... see my other post
THANKS!
scud:thumbup:
THANKS!
scud:thumbup:
