Hey everyone!
I just did the OEM Alarm Retrofit on my 03 325xi and everything went swell.
But while I had my car connected, I figured I'd pull up the Car/Key Memory Settings and I'm confused about a couple settings;
Anti-Theft System (bold = current setting)
My question is about the "hatches closed" options. The factory default for "Arming, acoustic (hatches closed)" is active, but I disabled it based on the description;
"Activation is confirmed by a brief warning signal from the siren once all the doors and hatches are closed"
If this was enabled, does that mean every time all my doors/trunk/hood were closed the siren would beep? or hazards flash (with the visual hatches closed setting)?
Thanks for the help!!
- Interior movement detector
- active
- not active
- Tilt alarm sensor
- active
- not active
- Activation/Deactivation
- deactivation via remote
- lock & remote
- Arming, visual
- active
- not active
- Activation, visual (hatches closed)
- active
- not active
- Decativation, visual
- active
- not active
- Arming, acoustic
- active
- not active
- Arming, acoustic (hatches closed)
- active
- not active
- Disarming, acoustic
- active
- not active
