1 - 4 of 4 Posts
I have a 2002 330i and out of the blue the LCD display under the instrument cluster -- the one that shows the odometer, clock, temp, etc. -- stopped lighting up. The other LCD displays that show the door ajar and the current gear also do not light up.
At first I could get them to turn on by playing around with the dimmer switch for the interior lights, but now even that doesn't work.
Does anyone have any thoughts/suggestions?
Sounds like it might be the ambient light sensor.
If you look at the controls for the lights you will see a small white dot (bad explanation but you get the idea). Try shining a torch light on there with your key in position 2.
Discussion Starter · #4 ·
Thanks for the advice. I don't think the problem is with the ambient light sensor because the other instrument gauges all dim appropriately.
I was think it could be the bank of lights (LEDs?) that are behind the computer readout but it seems strange that they would all go out at once.
1 - 4 of 4 Posts
