I have a 2001 BMW 325i. A few days ago, I noticed that the display board in the speedometer cluster where the odometer reading is remained lit after the vehicle was turned off and locked. An inspection later that night revealed that it was still lit several hours later. In addition, the headlight switch was also illuminated as well as the indicator on the automatic transmission (orange light at the "P"). The next morning I went to look into the issue only to find that the key fob no longer unlocked the vehicle, nor did it lock or operate the trunk. The central locking system operates from the button in the center console and from manually using the key in the door. I do not know if these issues are related, but the close proximity in time to one another suggests that they might be.
Thus far, I have checked the fuses for the central locking system (49, 52, and 60) and the instrument cluster fuses (10, 34, and 43), all of which are good. I have attempted to dim the display using the wheel on the headlight switch; however, this only seems to affect the instrument panel lights when the headlights are turned on. When the car is turned off, the display goes back to full intensity. I am unsure exactly where to start in terms of diagnosing this issue, therefore, any assistance would be greatly appreciated.
To ensure that I have accurately described the lights and displays in question, attached is a picture of the issue. Thanks in advance for any help in resolving this matter.
