Status
Not open for further replies.
OBD Fusion
3 reading
70K views 4 replies 1 participant last post by  Bali
#1 ·
If you have a smart phone or tablet, get an OBDII app and wireless adapter to see exactly what is going on with the engine fuel management system.
A quality OBDII tool supports the following:
  • Diagnostic Trouble Codes (DTCs) in Pxxxx format (such as P0171)
  • Individual emissions readiness monitors state
  • Live display of parameters (such as RPM, O2 sensors, fuel trims, MAF)
  • Freeze Frame parameters (stored when the CEL/SES light comes on)
  • Log many parameters (capture problems encountered while driving)
  • Export parameter logs in CSV file format (for analysis and sharing)
  • Upload CSV logs for sharing (review by experts for advice)
OBD Fusion and a proper OBDII adapter provide all these features, and are less than $40 for Apple iOS or less than $20 for Android. OBD Fusion is an app for your smartphone or tablet you use to to connect to your car for reading/clearing codes, viewing live engine data, logging engine data (for export and later analysis or plotting), viewing emissions readiness monitors, among other things. Here's a link to the OBD Fusion website.
OBD Fusion | OBDSoftware.net
OBD Fusion for Android - Google Play Store
OBD Fusion for iOS - Apple App Store
See this video for an overview of using OBD Fusion.
OBD Adapter
You'll need a wireless OBD adapter. The bluetooth LE one is by far the best.
  • VeePeak BT LE A Bluetooth LE OBDII adapter works well on both Android and iOS, is more reliable than WiFi, supports higher speeds, but is more expensive. BT LE is not supported on older devices, so first check if your device supports BT LE.
  • Veepeak WiFi A WiFi OBDII adapter works with both Android and iOS and is cheaper than BT LE. Some folks have had problems with it losing connection or connecting to other WiFi networks.
  • Veepeak Bluetooth For devices other than Apple iOS, a standard Bluetooth OBDII adapter will work and is cheaper than WiFi or BT LE. It does not work on iOS as Apple doesn't support the serial port protocol that BT OBDII adapters use.
Configure OBD Fusion
Read the attached PDF document on how to configure OBD Fusion and use it to run a Diagnostic Report, log parameters, and share the logs.
This write-up is Android specific. iOS support is similar, but the menu options may be slightly different.
Share Log Files
Upload your collected CSV log files to the datazap.me website and post links for review and advice.
Notes
  • OBD Fusion supports the OBD standard and does not support any BMW-specific modules or fault codes.
  • we recommend OBD Fusion here as it has all the important features, is very reliable, reasonably priced, has excellent support from the developer, and properly supports many OBD PIDs that other apps don't. We have no affiliation with OBD Fusion or its developer OCTech, LLC.
  • we recommend the VeePeak brand of OBDII adapters here as they've shown good quality, reliability, stand behind their products, reasonably priced, and readily available. We have no affiliation with VeePeak.
#3 ·
OBD Fuel System Status
1 - Open loop due to insufficient engine temperature
2 - Closed loop, using oxygen sensor feedback to determine fuel mix
4 - Open loop due to engine load OR fuel cut due to deceleration
8 - Open loop due to system failure
16 - Closed loop, using at least one oxygen sensor but there is a fault in the feedback system
#5 ·
The best way to get help for your engine running issue is do the following.
  1. Record the three standard logs using OBD Fusion following instructions in PDF attachment up in post #1.
  2. Upload the CSV log files to datazap.me website.
  3. Post link(s) to the logs in your thread and request a review and feedback.
Status
You have insufficient privileges to reply here.
