1 - 2 of 2 Posts
Hey guys. I swapped the engine in my 02 cabrio (just stock for stock) , and am in the final stages of getting it ready. I have unlocked the OBC function 7.0 that shows temp, and it says its about 75 degrees, but my needle is going high. Replaced front fan (manual trans) as well. I would think that 75 is in the normal range and should not get the needle to go north. I suppose it could be an air bubble will try a re bleed again tonight after cools down. Any other suggestions?
Also, my fan did not come with the relay mounted to the top of the fan, I had to reuse. Thinking that might be my culprit.
1 - 2 of 2 Posts
