If so, remove the whole flap with a hammer and chisel. One good whack should do it. Golf tee mod is only half of the solution.Are you sure it's not the exhaust flap closing ?
Yes, but it closes when you start the car.doesnt the flap default to open?
as the engine is turned off it no longer has vacuum and cant keep the valve closed. and either way if it was moving slow enough to have not opened fully by the time you get to the back of the car its probably moving slow enough not to make any perceivable noise... my vote is not on exhaust flap...I notice this every time now as I turn off the engine and walk around the back of the car and the rear diff makes this click sound. :dunno:
Uh, there's no reservoir for transmission or diff fluids. The reservoir labeled ATF is your power steering fluid....I checked the ATF today and it's quite dark brown. Auto of course. I assume the front diff shares the same fluid reservoir as the tranny?
Indeed . . my apologies =)Uh, there's no reservoir for transmission or diff fluids. The reservoir labeled ATF is your power steering fluid....
