How many thermostats have failed in your car(s)
  • 0
    Votes: 36 47.4%
  • 1
    Votes: 33 43.4%
  • 2
    Votes: 5 6.6%
  • 3
    Votes: 0 0.0%
  • 4
    Votes: 0 0.0%
  • 5
    Votes: 1 1.3%
  • 6
    Votes: 0 0.0%
  • 7 or more
    Votes: 1 1.3%
1 - 20 of 28 Posts
Slow in, slower out
How many thermostats have failed in your car or cars?
M52TU and M54 thermostats are a well known weak spot in BMW cooling systems. They usually fail open causing the car to run cold, usually throwing a check engine light. An OBDII code reader will show a P0128 (Coolant below regulating temperature). I don't know what the factory or Peake code is for this failure.
I had another one die this week. It failed closed while driving to work resulting in an instant overheat and steam display. I don't know if I damaged anything. A few more days of driving will be required before I know if I'm losing coolant due to a blown head gasket. My previous thermostats failed open.
As far as I know I haven't had one fail. While I did get a P0128 code a week or so ago, my fan was running excessively at the time (which I found odd) and according to a tech I discussed it with, that was the cause of the code. It has not shown up since nor have I had any indications of abnormal running temperatures. How many total have you had fail?
Slow in, slower out
Discussion Starter #5
The one that failed this week was #5 for me. A friend called me a freak of nature.
It didnt actually fail, but I had mine replaced with the updated thermostat around 50K for peace of mind.
Old part: 11530139877
New part: 11537509227
It didnt actually fail, but I had mine replaced with the updated thermostat.....
I did the same. I changed mine at around 80k as preventative maintenance.
None in 2 BMWs I owned (one M52Tu and one M54)and none yet in the one I own now(M54).
I have a brand new OEM thermostat siting in my basement,bought it when I put my Stewart WP in, as I heard many people experienced thermostat failure right after replacing wp to Stewart. 10kms(6k miles) later, still waiting for the original to give up but it wont.
Since we're there, I also have a new OEM expansion tank sitting right next to the thermostat in the basement, as I refuse to change it without seeing how long my original one can take. So far 180kms(112k miles), original thermo and ET.
On my previous E46 I had a leaky thermostat replaced under warranty at around 20k miles. Never had another issue in the next 40k with that car or the 10k miles or so that I have had my ZHP.
Sent from my iPhone using BimmerApp
Slow in, slower out
Discussion Starter #15
I appear to be the exception rather than the norm. I thought there would be more people with 3+ failed thermostats.
Oh well. I got 10 years out of the original battery, radiator, and coolant reservoir so I guess I'll consider the thermostats to be a small offering on the altar of crappy parts from Bosch/VDO/Behr/Siemens/Lucas/Tyco/ZF/Lemforder.
I replaced the first one at about 30K. I overhauled the entire cooling system a couple of years ago when the car was at about 55K. That one failed last week. It failed open, and I replaced it with a Wahler unit. I think that this was the same brand that I had used previously (both times). Never have had a thermostat issue before in almost 50 years of driving.
I replaced my original at 123,000 miles, not because it failed, but because I replaced it with a new one as preventative maintenance.
Mine stuck open at 125k
Lasted pretty long I guess :dunno:
1 - 20 of 28 Posts
