All right, I've about had it with this issue...time for a meeting of the minds. :thanks:
For some time now my 2000 328i has been plagued by an idle dipping issue that occurs when I brake and clutch-in, but do not re-engage a gear right away. So think of coming to a stop, hitting the brakes, and pushing the clutch.
Anyway, what will happen is the car's idle will drop down to 500 RPM (or sometimes lower) catch, and "bounce" back up above normal, then settle again. There are two variations on this theme. First, the idle will drop so far the car stall's, which is fine when you are coming to a stop, but if you are in a corner or on an exit ramp, causes you to lose power steering and is dangerous. I have learned to pop the clutch quickly, but that is hard on the car. Second, the idle will drop to 500, catch, drop again, catch, drop again, and so on in a vicious cycle until I punch the gas to knock it out of the cycle.
Despite my best efforts, I have been unable to replicate this issue consistently. It seems to get worse with warmer weather, but it happens in the winter as well. In my 3+ years of owning the car, the car has actually stalled six times, but the odd idling happens almost everyday. I have been able to replicate the dip somewhat by feathering the throttle when parked up to about 1,000 RPM, then removing my foot quickly. Doing this repeatedly will cause the car to go into the idle cycle I mention above.
Additionally, I could swear that I am lacking power (torque), specifically in the lower rev ranges (sub-3,000 RPMs). I have not dyno-ed the car just yet to prove this feeling, but I can tell the car does not have the snap acceleration it should have (I've driven many other e46's).
Lastly, this has plauged my car since I've owned it to varying degrees. I bought my car with 75,000 miles on it and it now has 135,000 miles on it. My car does not throw any codes and no codes are being stored (or at least that Autozone can retrieve).
SO, all that said, many of you have PMed me, responded to my previous threads, posted threads of your own, etc. Yet, to my knowledge, not one person has solved this problem for good. To date, I have taken the following actions:
1. Replaced Spark Plugs with OEM NGK
2. Replaced Fuel Filter
3. Replaced Air Filter
4. Replaced Oil / Oil Filter
5. Replaced Intake Elbow
6. Replaced Intake and Exhaust side Camshaft Position Sensors (CPS)
7. Replaced Fuel Pump
8. Replaced CCV
9. Cleaned MAF
10. Went to K&N Cold Air Intake
11. Installed Conforti Shark
12. Updated my DME via BMW (this procedure only helps on M54 engine cars from what I know...don't waste your money if you are M52, and even on M54, I don't think it "solves" the problem, only masks it like it does the VANOS seals issue)
13. Cleaned the ICV
14. Cleaned the DISA
15. Removed and cleaned the throttle body, butterfly valve, etc.
15. Repaired the VANOS seals, engine gasket, no sign of sludge
16. Replaced the oil filter housing gasket
17. Checked for and found no vaccum leaks
:banghead:
I think that is all of it, as far as I can tell fuel and air delivery are fine. Additionally, I have even read threads about how poor low end performance might be the result of bad differential bushings, etc. I don't really buy that stuff though.
Here are some of the other threads I and others have posted on this issue, feel free to add. I am subscribed to all.
http://forum.e46fanatics.com/showthread.php?t=693806
http://forum.e46fanatics.com/showthread.php?t=711966
http://forum.e46fanatics.com/showthread.php?t=586758
So where does that leave us, you ask? Good question. First, I hope you completed the poll above. If you have and do have this issue, please post the year of your car, the model number, your symptoms if similar, and what you have tried so far. My indy mechanic and BMW dealer are stumped.
Also, I have four more ideas to try :idea:, looking for feedback on these. First, I wonder if the oxygen sensors could be playing a role here. I do not believe this is the case, I have never thrown a code on an O2 sensor, and I don't think they were bad when I first bought the car, but who knows. I also don't think they would retard engine performance much if any at all.
Second, I just read a thread a bit ago that mentioned maybe the VANOS solenoid is bad. This is an interesting theory, and one I really like, because the VANOS was causing cold stall issues. If the solenoid is bad, maybe the VANOS is not functioning the way it should and causing stall / idle issues too. The part number, from what I can tell is: 11361432532 and costs $120 according to RealOEM.com. It is easy to replace. I am thining of trying this. Thoughts?
Third, I have considered the throttle position sensor, but do not believe this is it. Any thoughts here?
Fourth, I still would like to dyno the car, to prove that the perceived power loss is not just in my head. I also would be interested in the air/fuel ratios, etc.
Sorry for the long thread, but this is really bothering me, and I know it bothers others of you as well. TO THE MODS: if this thread gets some traffic, can we consider stickying?
Love you guys. :hi:
:eeps:
NicB.
8. Replaced CCV
9. Cleaned MAF
13. Cleaned the ICV
:banghead:
Love you guys. :hi:
NicB.
