I recently purchased my second E46 in the fall of 2020. One of the first things I took care of was bleeding the cooling system since I was getting an intermittent coolant light and little to no heat (I believe this gave me heat again for a short period of time). The previous owner had stated that he refreshed the cooling system the previous year, however when I noticed coolant began spraying all over the front of the engine, car overheating, coolant smelling steam/ smoke, and slow leak on the ground, I ended up refreshing it again. Here is what I replaced:
Mahle Expansion Tank
Mahle Thermostat
Graf Water Pump
OEM Coolant Temp sensor & gasket
Hudson (OE brand?) upper and lower hoses
After bleeding the system and letting the car get to operating temp, I noticed lots of steam/smoke coming from the radiator. At first I assumed that some of the coolant may have spilled on it and it was burning it off. After a few days this smoke has seemed to go away significantly, but I check and notice it from time to time after I get out of the car. I am considering replacing this just to rule it out, but I'm holding out until I get some feedback on my situation.
I still have no heat. I do believe I bled the system correctly as I also did the exact same procedure on my 2000 328i with no issues. The hoses are warm/hot after driving.
I did some research on here and was curious to see that some people remedied this problem with a new Final Stage Resistor? I do have one on order since my vents don't really blow any air at anything but the two highest settings, but I don't want to get my hopes up that that will be the fix.
Any help is appreciated. I still have a lot to learn about these cars and I hope this isn't too much info. First post!
Mahle Thermostat
Graf Water Pump
