1 - 15 of 15 Posts
· Registered
2002 325ci
2002 325 ci
During the morning drove the car around for about 2 hours. Parked came back a few hours later. No crank No start. Tried jump start. Tried push start (manual trans). When the door is open I don't hear the door chiming at me. I jumped the gray relay box (EWS) under the dash. I can get the car to turn over. Still no start. I have checked the fuses in the glove box, and they are all fine. I have not used a test light yet at the ignition switch to check power in and out. Any and all help would be greatly appreciate.
· Registered
2002 325ci
Discussion Starter · #4 ·
I have no door chime. I replaced ignition switch. Still no start. I don't have a tip smallest to fit into the pins at the ews connector. To check power or voltage.
I have a feeling it is just that the key somehow has 0 power and or the key has lost its programming some how.
I started looking and reading the e46 list of no start issues. There are almost 3k post in there to read through.
· Registered
Maybe u should get bmw scanner 1.4 ..and copy the cluster to ews or
Lcm copy to ews
Lcm copy to cluster
Because your lcm still has the original files and also not been changed..and if everything works good there should be no errors at the bmw scanner 1.4.
I wish u good luck..
1 - 15 of 15 Posts
