1 - 2 of 2 Posts
Vendor
This is a must-have for ALL BMWs, and simply replaces your existing differential drain plug. With every differential fluid change you perform on your BMW, you'll be able to inspect for metal shavings and debris. Many times, if something is going wrong on your BMW's differential, magnetic drain plugs can provide fair warning before larger issues can cause failures and incur costly repairs. Plus with the upgraded strength of titanium, sheared drain plugs are a thing of the past!
Turner Titanium Magnetic Differential Drain Plug - M22x1.5
1 - 2 of 2 Posts
