1 - 20 of 43 Posts
E46 F10 W204 W212
I did try to pull the old ones out more and it does not look like they are supposed to. When compressed the old ones still extend out again by themselves
If those are Biltein 22-139931 and 22-139948 then you have the right shock.
Discussion Starter #5
These are Bilstein 22-103109
Got them from ECS Tuning and it said that they fit my 330i and that they are for standard suspension
E46 F10 W204 W212
That's correct then. 22-103093 and 22-103109 for the standard suspension.
The original SACHS strut has an internal rebound spring, which is why it is shorter. When you try to pull out the SACHS strut you are compressing the internal spring. The rebound spring reduces body roll and improves handling. The Bilsteins do not have a rebound spring, which is why they are taller. If the car came with rebound springs from factory, you should only install equivalent parts that have rebound springs, otherwise you will compromise the handling of the car.
It's hard to imagine std is that much longer than sport. What happens when you pull on the old one?
E46 320d touring 2002
Read the stiker on your old strut and then look at this:
To identify your suspension
The body of the struts are the same, so the piston of the old one does not come out all of the way. I think the piston is stuck.
No need to worry. I swapped my old OEM (sport?) struts for Bilstein B8. And I can confirm that the OEM sport struts are incredibly short. No worries about this. Only problem is that you need to compress the springs REALLY hard to get the OEM strut loose. But this is already out of the way in your case :)
915652
i can't imagine getting the spring back on the old one. Surely it must come out more.
No, that's the correct idle height for the piston. I installed new SACHS struts back in September. I got the springs on just fine. Here's a pic of the parts I installed.
915667
Like I said, the OEM struts have rebound springs. Aftermarket dampers do not have rebound springs.
You can read more about rebound springs the PDF I attached.
err, no. It limits spring travel, so as to produce understeer after a certain amount of body roll.
It also softens the suspension travel limit, so the understeer comes on more gradually.
You get more grip with 4 tires on the pavement than 3. So since there's a lot of spring pressure and travel left
when the damper starts to lift the wheel, front grip is reduced. It may reduce body roll slightly,
but the reduction of grip from all that weight transfer to the outer,
heavily- loaded wheel far outweighs any benefit of roll reduction.
The limit spring also softens the crash when you drop a wheel into a pothole.
In the US, I thought all 330's got sport suspension. Or was that just the 2- door 330's?
Either way, the springs are different, and I thought that the shorter strut always had
the sport spring, with the non- sport getting the longer dampers and non- sport spring.
t
  • Like
Reactions: hurls
Oh, the old Zuganschlagsfeder! Now I understand. I've only done the rears so this is new for me. Thanks. Nice looking pile of parts!
t
No, only the coupes and convertibles, in 2002 and on cars. Sedans got comfort suspension unless specced for ZHP or ZSP packages.
Does the coil spring pull the piston rod out as it expands during install? I'm still amazed that teh spring will collapse to that height. Just curious. I don't like spring compressors.
2004 325i automagic
Rebound spring or no, the Bilstein B4s are a viable and commonly used replacement strut. The difference between standard and sport suspension ride height is about 1/2 inch or so roughly speaking, so that would not account for such an extreme difference in strut piston length as shown in OP's picture.
I was under the impression that all 330i after a certain point came with the sport suspension without it being listed as an "option". Not exactly sure when that cutoff was.
1 - 20 of 43 Posts
