1 - 4 of 4 Posts
Premium Member
hello fanatics
i'm a proud owner of a used 2001 330xi
bought it used thru a used car dealership
its got harmon kardon stereo, winter package, sports package, but does not have Xenon lights
it has 49200 miles on it. production date is about 03/2001 and I don't have records of its maintainence history, nor do i have the Owner's manual, I have one key. I do have a VHS tape and a CD-ROM
Have a few questions:
BMW Warranty expires at 50,000 miles and i've noticed two minor items that need to be fixed.
1) Front driver headlight is out and the left turn (arrow) indicator blinks and bells twice as fast as the normal right turn (arrow) indicator. this is a minor problem, but will the dealership service fix this under warranty?
2) Can and will the BMW service dept pull up the past history of this vehicle if it has been to other BMW dealerships for routine maintainence and service?
3) Can I get a couple of keys and can they tell me the code for the business radio in case i need it or can i just get the keys made somewhere else?
4) Are there any items that I should mention to them to do or to check closely before the 50,000 miles warranty expires
5) Which performance mods would you recommend as the top 1, 2, and 3 to do to the BMW 330xi (Shark injector, CAI, etc)
6) I have an Alpine 9811 MP3/XM headunit that I would like to put in. It would probably look a bit out of place, but what do you suggest doing to get a new headunit?
stoneweed1 said:
hello fanatics
1) Front driver headlight is out and the left turn (arrow) indicator blinks and bells twice as fast as the normal right turn (arrow) indicator. this is a minor problem, but will the dealership service fix this under warranty? I don't think the warranty will cover the lights past 3yrs / 36,000 miles. The reason one side is blinking faster than the other is b/c you have another burnt out turn or side marker indicator. Sometimes they may not even be burned out, just have a little corrosion on them that can be cleaned off and reinstalled.
2) Can and will the BMW service dept pull up the past history of this vehicle if it has been to other BMW dealerships for routine maintainence and service? I believe they can, but I'm not sure if they will or not.
3) Can I get a couple of keys and can they tell me the code for the business radio in case i need it or can i just get the keys made somewhere else? Keys HAVE to be ordered thru the dealer.. if you want the full function keys, your looking at about $120 a piece. Not sure about the code for the radio.
4) Are there any items that I should mention to them to do or to check closely before the 50,000 miles warranty expires? Check for shock tower and subframe damage.
6) I have an Alpine 9811 MP3/XM headunit that I would like to put in. It would probably look a bit out of place, but what do you suggest doing to get a new headunit? Try the ICE forum.. I have never modded the radio on a BMW.. looks out of place to me.
1. yes, they will service the car for what you listed
2. yes, they can get the history of what they have
3. Yes you can get the keys, but it will cost you, up to $200 for a full function key
4. Just tell them to check everything, at worst, you will be out a couple of $100 bucks for any inspection they do but I think they would do it under warranty
5. No much help here, start with software, cai, and catback
6. Take the car to a pro and have then do a custom job
7. BMW will give you the business code for the radio as long as you are the owner on record on their computers.
-hope this help.
1 - 4 of 4 Posts
