Thanks for everyone's support. Special thanks to TitaniumCranium for posting your pics.
Challenge: How to remove power steering hoses without white plastic tabs. I tried several otions including making my own replacement white tab out of sheet metal including purchasing after market a/c disconnect tools as shown in the first picture below. NONE OF THOSE OPTIONS WORKED including the special BMW tool.
My Solution: Use a Dremel carefully with a small disc. Cut carefully at the metal head just enough to clear the metal on the end. Then carefully use needle nose to pry off. It's a pain in the ass, but the key is take your time. The plastic nipples on the cooler appear to be plastic.
Total parts cost around 100 bucks.. replaced all power steering hoses and fluid. Dealer estimate upwards of 700.
If your white plastic tabs are not broken off, buy the BMW tool listed in this thread.
Good Luck! :thumbup:
