So after somewhat extensive (relative term) research I ended up with Turner Brake kit and got them installed yesterday. The kit included Axxis Ultimate brake pads, OEM Stock rotors by Zimmerman, blue fluid and sensors all for $480 shipped. I was under the impression that the OEM rotors are by Brembo, am I wrong? I am not sure why I got Zimmermans instead…..how do they compare to Brembo in OEM stocks?
I was also under the impression that these Ultimate brake pads were better than OEMs? But boy was I given wrong info. These Ultimates don’t even have half as good a grip as my old worn out OEM pads (even after the light was on). Am I missing something? I mean, do I need to wait a while before making any judgment?
Then I ran into the calipers rubbing against my wheels with these ultimate pads. I have a staggered setup of Beyern Mesh 18X8.5/9.5, ET 40/45 with Nitto Invo 225/40/18 and 255/35/18 tires. Are these pads too thick for my wheels or the wheels are the issue? If that's the case then why didn't they rub with my oem brake pads? The shop had to grind my caliper down so they don’t rub......is that an acceptable fix or will it cause issues later?
Man after this horrible experience, do I wish I went with OEM set, even if it was $120 more…….sigh!!:ben:
Now the last issue is my brake sensor light is not gone. I tried resetting the light by turning the key in POS 2 and then leaving it there for 2 mins but it is still there…..what else can I do to get rid of that damn light?
