1 - 11 of 11 Posts
hi guys having trouble with setting the clock on my 51 plate 318i read aloud of your posts on this subject but to no avail upto yet well here goes the peg to the right of the speedo only gives me cels/faranite the button on the indicator arm doesnt do anything ive tried slowly turning the ignition till it 1st light up but no clock if i hold in the peg on speedo and slowly turn ignition i get what looks like a clock time but that dissapears the same is on the radio just the --/-- marks is there a easy fix a mate of mine got the same prob on his 02 plate 318i cheers guys KARLOS:banghead:
Discussion Starter · #5 ·
basically guys cant set the clock the way it should be set what im being told isnt working its got to be something simple HELP:ben::ben:
Look, it's easy. Push the button on cornering light stick until you see a clock on your board computer, then set it up with right button on instrument table, under rpm gauge (I guess that's the one you supposed didn't do a thing) - by rotating it just one notch (that's as far as it goes) to the clockwise or counterclockwise direction. I hope you understand, I know my English is not the best, but I see your is even worse and, so I don't care :)
1. Turn key to the 1st ignition switch
2. Press the button on the left steering wheel stick inward towards the wheel (it's a button on the tip of the high beam stick that presses ---> ways).
3. Press it until you reach the clock setting (you'll cycle through temperature and mileage I believe)
4. Once at the clock you'll need to reach behind the wheel and turn the right push-knob on your gauge cluster (the one that show miles driven, etc.)
right = + minutes
left = - minutes
It takes awhile so hold it for a few secs until it starts to pick up.
Done :thumbsup:
When I did mine I had to twist it a bit harder than I felt comfortable doing. When you rotate it enough mine made a small click sound.
Discussion Starter · #9 ·
thanks for the replies guys even (even the sarky 1? HUCKERFAKER) what im trying to get across in my question is this the switch on the indicator stalk doesnt do anything to take me to clock settings how ever long i hold it in
you don't hold it in, you just press it. keep pressing it until the clock appears in the screen
1 - 11 of 11 Posts
