Guys I am going to search myself in a minute .. but I'm hoping one of you will know the answer. I'm giving you the short version
- Our sept 2002 built 325ci (I think late 2002 were sold as model year 2003 ) runs gret most of the time , But can't get emissions done because EVAP and cat won't finish. O2 Sensors and MAF are DEFINATELY working pretty well. I'm getting the dreaded "Lean" P0171" & P0174 whatever it is for bank 1 and bank 2. It goes for 2 days then ... on again. I clear it and we continue ..the circle of BMW life ad-nausea
I've smoked the SH#$ out of it with a serious smoker. I've smoke thru oil cap, I've smoked via Air Duct at the MAF. I've SMOKED both directions. of the power brake. I've smoked so much I need to get my own lungs checked. There are no external leaks. I can find.
But recently I saw a few models of 325 have this "leak detect pump" behind the engine and on those the little 1/8 tube on the Sec Air Pump valve goes to that pump
On a whim I pulled the 1/8 inch tube from the SA pump valve (it heads back along the Head and disapears somewhere) .
blew into it. It is wide open. with a cold engine. Is that right? did I find my air leak? What does that little tube do?
When I blow into the same size tube from the the post MAF "F" connector it is completely shut. I believe that one goes to the fuel pump purge housing.
I'm just sitting here .. hoping MrMcar , NA, Or NZ will see this ...
txs
txs
