1 - 7 of 7 Posts
What is the proper ft. lbs. of torque to tighten lug nuts?
:confused:
It will vary but I believe the owners manual say around 62 lbs./ft. You just don't want to over tighten aluminum wheels.
Discussion Starter · #3 ·
I called the dealer and they told me 85 to 95 ft. lbs. I torqued them to 90 and after 2 miles the lug nuts were loose. Maybe the wrench is bad, cause 90 did not feel very tight.
:banghead: :banghead: :banghead:
can ya spare some change?
the correct torque setting according to BMW for the e46 is 85Nm or 62.7lb/ft.
Its almost scary how many dealerships overtorque stuff cause they will see 20Nm as 20lb/ft or 80Nm as 80lbs/ft :tsk:
1 - 7 of 7 Posts
