1 - 9 of 9 Posts
Getting my axxis pads installed today and need to know the proper break in steps.
Thanks for the help.
:) :D
Discussion Starter · #3 ·
Thanks,
I thought I remembered reading that you had to ride the breaks for short periods of time or something like that????
St. Louis BMW Fanatic
Cybertek said:
Thanks,
Yeah, I've heard a bunch of different break in methods but that's what I normally do and everything is fine up to this point. The main thing is to build up some heat in the pads and rotors.
...and I'd be all shiny..
What was the suggested anto-squeal compound that alot of people use to keep the noise factor out for those of us whose Axxis pads squeal?
I use the stuff made by NAPA...it's just a bottle of red paste...I think it's labeled "Disc Brake Quiet" or something like that. It's about $4.00 from Autozone...
Modelrater
yep. I believe that's the same thing i used.
quick tip:
apply the compound before you start taking the wheels off. you need enough time for the compound to set. i forgot how long. i believe an hour or so. good luck! :D
Conrad said:
quick tip:
Good advice. That's what I do too. It takes 25-45 mins to set depending on the temperature and humidity.
Discussion Starter · #9 ·
I found something called "Disc Brake Quiet" made by Permatex at Autozone.
Any one used this?
Is this what you were refering to vinnymac???
1 - 9 of 9 Posts
