1 - 11 of 11 Posts
I need a source to tap into that has power when the ignition is on. Problem is I need it not to stop having power as the car cranks over. Anyone got any ideas?
Discussion Starter · #3 ·
crispvx said:
Tap into your radio harness, I think the wire is purple and white.
There is also a 12v switched power supply behind the sunroof switch panel.
I believe these two both loose power during cranking..... :dunno:
I'm curious, what is it for?
And there's a thread or two about tapping into the headlight wiring for the garage door opener, but that's obviously not what you're looking for, so there's no point in me saying it. :hi:
None of the wires at the ignition harness do that (I just installed a remote start in my car, so I tested all the wires). I am not sure if you are going to find a wire somewhere else in the car that cuts off while starting. :dunno:
1 - 11 of 11 Posts
