Ok guys, Im not an expert in audio, but i already ordered my setup through research. I got JL stealthboxes, powered by a 300watt Xtant mono amp(150W @ 4ohms for the stealths), and am getting a alpine 9813 Headunit. Now, what i was thinking of doing is replacing the HK Sub amp, but leaving the main amp powering the speakers/tweaters/etc.
What i read is that the stock system uses differential outputs, not RCA, so you need line out converters and also that there could be compatibility issues with the HU. What I want to know is what do I need to make the Alpine headunit work with the stock system?Can I use the stock CD changer with the new HU?......what do I need to do to get the cleanest sound out of the amp/subs (since i need to use a Line-Out converter). Where exactly do I place the Line Out converter to convert the signal into RCA? Where can i get a really good Line Out converter?
Thanks in advance guys.
This is a modified diagram, originally done by VinnyMac(hope you don't mind).....I was wondering if this setup will work.
