1 - 20 of 34 Posts
So I had to replace my oil separator and hoses . I replaced all my spark plugs & coils & O2 sensor. And it's still misfiring and SEL light is on.. Can some one please help I've spent a lot and I need some piece in mind and help me figure this out..please and thank you..
Discussion Starter #3
PLEASE HELP ME W/My 323ci
:cry:
So I had to replace my oil separator and hoses . I replaced all my spark plugs & coils & O2 sensor. And it's still misfiring and SEL light is on.. Can some one please help I've spent a lot and I need some piece in mind and help me figure this out..please and thank you..:banghead:
Check to make sure you didn't accidentally disconnect the intake cam sensor. It is easy to do and easy not to notice. You will have to remove the air box.
Re: PLEASE HELP ME W/My 323ci
Post all the codes you are getting.
Discussion Starter #10
1188 fuel control (bank 1sensor 1)
1189 fuel control (bank 2 sensor 1)
0305 misfires on cylinder 5
Did you plug the small vacuum line from the fuel pressure regulator back into the CVV?
Did you replace the O-rings on the air spreader?
You still have a vacuum leak. May need a smoke test to find it.
You need to do a smoke test, there is probably a vacuum leak.
Can your code reader display freeze frame? If yes post it.
Discussion Starter #19
So I did the smoke test and found that my crank case vent hose to oil separator was bad so I replaced that today and still misfiring
Have you cleared the code and it came back still indicating Cylinder 5 misfire?
1 - 20 of 34 Posts
