1 - 3 of 3 Posts
Hey I'm trying to find out if anyone is running with 245/40-18 on the rear of a 2004 325i stock suspension or similar or if that would even fit on a sedan. Also could or should I run 225/40-18 on front as well. Tire guy recommended those tires for the rims I wanna get. Rim specs are:
Front: 18x8 35mm offset
Rear: 18x9 35mm offset.
Tire guy recommended those tires for the rims but didn't specify if those would even fit on my car. Any help would be greatly appreciated!
:I'm running stock 205/55-r16 90h on now if you need that info
225/40 18 will be what you want for the fronts. You could possible run 235/40 18 as well.
The rears should be either 245/35 18 or 255/35 18. The 245s are a safer bet without rubbing however both should be fine.
1 - 3 of 3 Posts
