1 - 4 of 4 Posts
Pulling manual trans on car.Star bolts on bellhousing verry tight.300# air gun is not working. tight quarters. Got a solution, or do I pull motor and trans?
Premium Member
2016 340i & 2002 325Ci
Soak them in Liquid Wrench, is it the top ones? I'd say long extensions and a breaker bar.
Agree with orb. The long extension absorbs all the torque from the airgun, use a breaker bar to loosen then the airgun or ratchet to remove the Torx bolts.
1 - 4 of 4 Posts
