1 - 8 of 8 Posts
Anybody got a link to a DIY on changeing the fuel filter? Its for my 04 330ci. I know theres some on here. Appreciate the help in advance
It's very simple. Remove cover and loosen hose clamps. Carefully pull off hoses. Remember which line goes where. Fuel will leak out considerably so catch it with a glass jar or other static free container. Install new filter, tighten clamps. If needed replace old vacuum hose rubber. Reinstall shield cover.
ya...
You might want to pull out the fuel pump fuse, start the engine until it quits a couple times.
The fuel line may be pressurized.... Pulling the fuse and starting will de-pressurize it.
Tie shop rags around your forearms. Wear glasses.
Probably will need a dental tool to slide under and all around the hoses so they pull off much easier. Might need a pliers or Channel-lock to grab and pull.
Take a pic of the old setup so you know which lines go where.
This is a biggie. Long story short I was rinsing my eyes out with the hose for what felt like an eternity.
Just finished replacing the fuel filter in my 330i. Here are some pointers:
1. Blue line goes to the center tube off the fuel filter. If you cant start the car after, you attached it wrong. Sorry bud! (How do I know this??)
2. Pull fuse. Hardly any, less than a liter, of gas spillage.
3. That lil vacuum line is fragile. Dont pull too hard on it. It will break. Mine didnt but I coaxed it out.
4. All in all not a bad DIY at all. I replaced the 5 clamps that need to be removed. Didnt pull the skid plate off, just bent it back. It doesn't break. Welll mine didn't, but I have zero rust too. (Texas car)
5. Hate those stock clamps. No way you can reuse them easily. Do yourself a big favor, get some clamps!!
Oh...and don't smoke while your doing this job. (Just a tip)
1 - 8 of 8 Posts
